Старый 15.07.2010, 20:08   #1
kamalblogs: Exists methods don’t need table declaration in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...d-declaration/
Do you know when we use select statement for conditional checks, we don’t need to declare a variable if we use the same name as the table. Look at the example below to understand better.
static boolean SelectStatementInBooleanConditions()
    //no declaration for table object has been made.
    boolean test;     ;
    //testing a variable
    test =  (select firstonly salesTable).salesId ? true : false;
    //if condition
    if ((select firstonly salesTable).recid)
        return true;
    //switch statement
    switch ((select firstonly salesTable).recid)
        case 0:
            return true;
        case 1:
            return false;
    default:
            return false;
    //return statement
    return ((select firstonly salesTable).recid);
In standard you can find similar usage extensively in exists methods. This can make your code smarter and simpler
Run the job and see that you dont get any errors……
kamalblogs: Virtual Convergence Dynamics Ax — Don’t Miss it !!! Blog bot DAX Blogs 0 03.06.2010 13:05
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 03:48.
