Старый 29.08.2009, 04:49   #1
Solutions Monkey: Persisting Filter conditions in EP Grid
Источник: http://blogs.msdn.com/solutions/arch...n-ep-grid.aspx
Persisting Filter condition in EP Grid
In AX 2009, EP grid control comes with an advanced filter. Here is a code to persist the filter condition the user last entered in a page for that user, so that later when the user comes back to the same page the last filter is applied and user didn’t have to reenter then.
This code sample assumes a dataset with the name “EPSalesTableList” which contains the datasource “SalesTable”
(1) First override the pack method of the dataset ( EPSalesTableList in this example) in AOT
public container pack()
container ret;
SysLastValue sysLastValue;
formdatasource filterDataSource;
filterDataSource = SalesTable_ds; // Put your datasource name
    ttsbegin;
       // Delete last saved query for the current dataset
    delete_from sysLastValue
        where sysLastValue.Company      == curext()
           && sysLastValue.UserId       == curuserid()
           && sysLastValue.RecordType   == UtilElementType::DataSet
           && sysLastValue.ElementName  == filterDataSource.name()
           && sysLastValue.DesignName   == filterDataSource.name();
    // If there is a new queryRun() object then serialize and save it
    // in the sys last value table
    if (filterDataSource.queryRun())
        sysLastValue.RecId = 0;
        sysLastValue.Company      = curext();
        sysLastValue.UserId       = curuserid();
        sysLastValue.RecordType   = UtilElementType::DataSet;
        sysLastValue.ElementName  = filterDataSource.name();
        sysLastValue.DesignName   = filterDataSource.name();
        sysLastValue.value = SysQuery::packRangeAndSortorder(filterDataSource.queryRun().query());
        sysLastValue.insert();
    ttscommit;
    ret = super();
    return ret;
(2) Second override the init method of the datasource ( SalesTable in this example) within that dataset in AOT
public void init()
    Query savedQuery;
    super();
// get the last value from the  sys last value table
    select firstonly sysLastValue
           && sysLastValue.ElementName  == this.name()
           && sysLastValue.DesignName   == this.name();
    if (sysLastValue && sysLastValue.Value)
              // If there is an unpack error delete the saved query
       if (!SysQuery::unpackRangeAndSortorder(this.query(), sysLastValue.value))
            ttsbegin;
            ttscommit;
Make sure you replace the datasourcename variable filterDataSource in the pack method with your datasource name.Save the changes, refresh AOD and now go to the page that is using this dataset and enter some filter condition & apply. Close the browser and reopen the page. Now you should see that the filter that you last applied before the browser was closed is still applied in this page.
Arif Kureshy, who is the dev manager for EP came out with his code snippet. So thanks to him for providing this sample code.
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites Blog bot DAX Blogs 0 04.04.2009 03:19
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: EP SSL ( https) Setup Blog bot DAX Blogs 0 23.10.2008 12:05
Solutions Monkey: EP Deployment - Internals Blog bot DAX Blogs 0 21.10.2008 20:05
Solutions Monkey: How to alternate the background color of each row in Web Grid in EP 4.0? Blog bot DAX Blogs 0 12.01.2008 12:31
Часовой пояс GMT +3, время: 00:26.
