Старый 10.07.2009, 17:05   #1
Fred Shen: Caller information in EP2009
Источник: http://fredshen.spaces.live.com/Blog...E4E3!272.entry
If we want to get the caller page information in Enterprise portal 2009 which is similar to what we did in AX native client programming -
element.args().caller();
We can implement the following code in the user control:
using Microsoft.Dynamics.Framework.Portal;
private string GetElementCaller()
    string sPath = AxWebSession.GetPreviousURL(this.Page).ToString();
    string [] words = sPath.Split(‘/’, ‘?’);
    string caller = “”;
    foreach (string word in words)
        if (word.Contains("aspx"))
            caller = word;
            break;
    return caller;
Add a Label control on the ascx file with ID 'Label1' and put the following code in the Page_Load method
protected void Page_Load(object sender, EventArgs e)
   if (!this.Page.IsPostBack)
      this.Label1.Text = GetElementCaller();
You will get the result like ‘EPProjTableInfo.aspx’.
Fred Shen: Limited sessions in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Axapta build number Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Access a method of formDataSource's field Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Adding covering indexes for aggregate function Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 08:49.
