Старый 17.10.2018, 11:11   #1
dynamicsnavax: Send file to temp blob storage in #MSDyn365FO
Источник: http://dynamicsnavax.blogspot.com/20...torage-in.html
In this post I will talk about sending a file to a temporary blob storage. A little warning before I get into it.
This is using the Microsoft’s blob storage that is provisioned for us. I haven’t given it a lot of thought on how it would behave in production. Take it at your own risk.
Lets start by looking back on a couple of posts last month on printing a report to a byte array.
http://dynamicsnavax.blogspot.com/20...-via-x-in.html
http://dynamicsnavax.blogspot.com/20...t-as-byte.html
You can use those sample pieces of code to get a report as a stream and send it to the below code.
if (stream)
str fileName = 'myfile';
str contentType = 'application/pdf';
str fileExtension = SRSPrintDestinationSettings::findFileNameType(SRSReportFileFormat::PDF, SRSImageFileFormat::BMP);
FileUploadTemporaryStorageStrategy fileUploadStrategy = new FileUploadTemporaryStorageStrategy();
FileUploadTemporaryStorageResult fileUploadResult = fileUploadStrategy.uploadFile(stream, fileName + fileExtension, contentType , fileExtension);
if (fileUploadResult == null || !fileUploadResult.getUploadStatus())
warning("@ApplicationPlatform:FileUploadFailed");
else
downloadUrl = fileUploadResult.getDownloadUrl();
if (downloadUrl == "")
throw Exception::Error;
A download URL will be generated for you. The URL is going to be public and with an expiration (15 minutes I believe).
Below is an error if you try to access it after the expiration period.
dynamicsnavax: Send to Azure Service Bus in #MSDyn365FO Blog bot DAX Blogs 0 30.09.2018 15:14
ievgensaxblog: D365FO. Working with Azure File storage. Blog bot DAX Blogs 0 16.07.2017 13:14
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
Microsoft Dynamics CRM Team Blog: Understanding Storage and Storage Notifications in Microsoft Dynamics CRM Online Blog bot Dynamics CRM: Blogs 0 25.07.2013 08:12
Часовой пояс GMT +3, время: 11:15.
