dax-lessons: Create Technical Document from AX
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!139.entry
============== Creating detail technical document in projects is very time consuming. Isn’tit? Particularly if there are many objects in the project it will take more timein creating it. The jobs which I am going to explain will reduce time in preparing technicaldocument. This job will list the table fields properties like table field name,help text(Description),type, Size etc. static voidsgx_TehnicalDocument_Tables(Args _args) { COM document; COM wordDocument; COM wordRange; COM app; str tableContent; SysDictTable dictTable; SysDictField dictField; Counter fieldCounter; Counter arrayCounter; str typeofTheField(DictField df, Types _types) { str typeName; SysDictType dictType; SysDictEnum dictEnum; ; switch(_types) { case Types::UserType : dictType = new SysDictType(dictField.typeId()); returndictType.name(); case Types::Container : return 'container'; case Types::Date : return 'date'; case Types::Enum : dictEnum = new SysDictEnum(dictField.enumId()); if(dictEnum) return dictEnum.name(); case Types::Integer : return 'int'; case Types::Int64 : return 'int64'; case Types::Real : return 'real'; case Types::Record : return 'record'; case Types::VarString : case Types::RString : case Types::String : return 'str'; case Types::BLOB : return 'blob'; case Types::DateTime : return 'datetime' ; case Types::Guid : return 'guid' ; default : return ''; } } ; app = new com("Word.Application"); app.visible(true); document = app.Documents(); wordDocument = document.add(); wordDocument.activate(); wordRange =wordDocument.range(0,0); dictTable = new SysDictTable(tablenum(CustTable)); // Mention your table here <strong><span style="color:rgb(153, 51, 102);font-weight:normal"> for (fieldCounter = 1; fieldCounter
| Опции просмотра | |
