Старый 30.05.2019, 15:11   #1
erconsult: Refresh master data cache in D365FO
Источник: http://erconsult.eu/blog/refresh-masterdata-cache/
Having imported deeply cached master data into the D365FO Production environment (such as ‘entire table’-cached project groups, absence groups etc.), you may find the target form seemingly empty. An attempt to create the records manually with the same IDs fails with a “Record already exists…” error message. I.e. the data has been imported by the Data management framework, successfully loaded into the Azure SQL Database but not visible to this application server instance.
Solution: execute the below command in the browser, then reload the form:
https://xxxprod.operations.dynamics....s=SysFlushData
This launches the SysFlushData class known from previous AX versions with the help of the SysClassRunner shell and force refreshes the cache.
The post Refresh master data cache in D365FO appeared first on ER-Consult.
За это сообщение автора поблагодарили: trud (1), Logger (1).
Старый 30.05.2019, 19:42   #2
fed is offline
fed
Аватар для fed
2,913 / 5736 (197) ++++++++++
Интересно - а он на одном сервере (как в DAX2012) или на всех сразу кэш сбрасывает ?
За это сообщение автора поблагодарили: sukhanchik (4).
sysclassrunner
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
kurthatlevik: Master data concepts Blog bot DAX Blogs 0 18.02.2016 12:11
axsa: Power BI and Dynamics AX: Part 4: Data Refresh and Q&A Blog bot DAX Blogs 0 25.02.2015 20:12
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 17:05.
