erconsult: On the AXSCDPPKG file structure
Источник: http://erconsult.eu/blog/axscdppkg/
============== Application hotfixes for Dynamics 365 for Finance and Operations are distributed via AXSCDPPKG (AX Source Code Deployable Package) files. They can be downloaded from the LCS Issue Search page. The deployment process with the help of the SCDPBundleInstall.exe utility as described in this working instruction. However, prior to the installation you may want to quickly review the code to check if this is what you are looking for. The LCS Metadata hotfix is nothing but a set of 3+ nested ZIP files, quickly recognizable by the “PK” magic bytes in the header: ![]() ol { list-style-type: decimal; list-style-position: inside;}li { margin: 20px 0;}
Модератор
-ТСЯ или -ТЬСЯ ? |
| За это сообщение автора поблагодарили: EVGL (5). | |
| Теги |
| d365fo, hotfix |
