Старый 11.07.2018, 02:46   #1
emeadaxsupport: Dynamics AX 2012 Reporting: Error “Client found response content type of ”, but expected ‘text/xml'” when running a report based on cubes
Источник: https://blogs.msdn.microsoft.com/axs...ased-on-cubes/
You may run into this error running OLAP reports on a SQL Server 2016 Reporting Services instance on which the ENU\x86\SQL_AS_ADOMD.msi component from the Microsoft® SQL Server® 2012 SP1 Feature Pack was not installed. SYMPTOMS: When running the report in AX 2012 client you will see this error in the info log: “Client found response... Read more
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting - tips how to improve performance Blog bot DAX Blogs 0 18.09.2013 17:11
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
Часовой пояс GMT +3, время: 08:55.
