Старый 23.01.2018, 01:17   #1
crminthefield: Missing App URL Suffix after importing app via a solution
Источник: https://blogs.msdn.microsoft.com/crm...ia-a-solution/
I recently ran into an issue with a customer that wasn’t well documented, so I wanted to share via our blog in case others run into this issue. Scenario: My customer created an application in v8.2 (Works the same in v9) and added an App URL Suffix so that they could access the app directly...
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
dynamicsnavax: Daxeam Mobile Solution Released on Apple App Store and Google Play Store Blog bot DAX Blogs 0 14.09.2017 13:11
emeadaxsupport: The “ADFS URL” parameter has not been configured when setting-up workflow approval via email – Dynamics AX 2012 Mobile App Connector Blog bot DAX Blogs 0 01.09.2016 01:18
crminthefield: CRM 2011 Solution Import Fails with error “Object reference not set to an instance of an object” due to missing relationship “goal_DuplicateBaseRecord” Blog bot Dynamics CRM: Blogs 0 10.04.2012 22:11
crminthefield: Using a Console App to Fire a CRM 2011 Workflow Blog bot Dynamics CRM: Blogs 0 28.01.2012 02:16
Часовой пояс GMT +3, время: 06:38.
