Старый 03.11.2016, 10:11   #1
organicax: Tile data cache
Источник: https://organicax.com/2016/11/02/tile-data-cache/
If you are starting to work with D365FO then you might want to use the tiles that you find on the workspace. For performance reasons there is a cache that is kept to display the count on these tile if the developer has provided that. You can configure this in the system administration menu.
Here is a quick overview.
D365FO 1611 – Update3 (7.0.4307.16141)
If you are looking for an overview of the tile cache you can refer to this link
Tile and list caching for workspaces</p>
Cheers
Lachlan
Filed under: Infrastructure, User tips
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
kurthatlevik: Master data concepts Blog bot DAX Blogs 0 18.02.2016 12:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 11:38.
