Старый 11.08.2016, 06:14   #1
organicax: Item filters cannot use wildcard – message when using item template
Источник: https://organicax.com/2016/08/10/ite...item-template/
I had this question when working with a customer that I thought might share for others in case you run into it. If you are setting up the new R3 wms and same in AX7 and are using the template to setup your item it might apply to you. If you get the message “item filters cannot use wildcard” when trying to ally the template then you have to set the parameter on the filters tab of the warehouse management parameters.
Here is a quick overview.
AX2012 R3 Cu10.
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS menu – movement by template Blog bot DAX Blogs 0 12.05.2016 20:14
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 04:54.
