Старый 16.12.2015, 13:11   #1
mfp: X++ in AX7: Extension methods
Источник: http://blogs.msdn.com/b/mfp/archive/...n-methods.aspx
Have you ever experienced a Microsoft provided class or table missing that vital method that would just make your life easier? If so, you might have been tempted to add it yourself using overlayering. And you surely have paid the upgrade price!
You are about to be pleased. In AX7 X++ supports extension methods, similarly to C#.
Suppose we want to add a fullName method to the DirPersonName table. Here is how you do it, without touching the DirPersonName table. Create this new class:
static class MyDirPersonName_Extension
static public PersonName fullName(DirPersonName _person)
return strFmt('%1 %2 %3', _person.FirstName, _person.MiddleName, _person.LastName);
Things to remember:
  1. The class must be postfixed with "_extension".
  2. The class must be static.
  3. The extension methods must be static.
  4. The type of the first parameter determines which type is extended.
Now you can enjoy your extension method:
DirPersonName dirPersonName;
while select dirPersonName
info(dirPersonName.fullName());
Notice:
  1. When calling extension methods, you don't provide the first parameter – that gets inferred from the instance's type.
  2. If the extension method took any additional parameters – they (of course) needs to be provided.
  3. This doesn't break encapsulation. The extension method only has access to public fields and methods on the type.
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 TECHNICAL PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
Старый 16.12.2015, 17:50   #2
дока из c#
https://msdn.microsoft.com/ru-ru/library/bb383977.aspx
вот как подобная задача решена в Котлине
https://kotlinlang.org/docs/reference/extensions.html
Старый 17.12.2015, 12:23   #3
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (11) ++++++
Как-то вопросы возникают по этому примеру...
- Как найти в АОТ этот класс расширений учитывая что он фактически никак не привязан (или эта тема не раскрыта) к оригинальной таблице DirPersonName (название класса MyDirPersonName_Extension)
- Если кто-то перекроет этот метод на таблице (или он просто появится в следующем хот фиксе) - как это будет разруливаться? Не усложнит ли это только апгрэйд?
Я не знаком с данной концепцией в C# и сужу только по данному примеру, поэтому заранее прошу прощения за возможно глупый вопрос...
Zhirenkov Vitaly
Старый 17.12.2015, 13:12   #4
Link is offline
Link
Британский учённый
Аватар для Link
568 / 523 (19) +++++++
Записей в блоге: 9
Рискну предположить, что так же, как и EvenHandlers в 2012, т.е. ручками открывать классы в АОТ и вбивать имя объекта, смотреть есть ли класс с _extension и уже там искать метод. Возможно будет какой то индикатор на методе указывающий на существование его в классе _extension. К слову в DEV Tools есть быстрая навигация практически к любому связанному объекту, в том числе к коду EvenHandlers, если API будет позволять, сделать подобное в 7ке не должно составить труда.
Мне кажется, что как EvenHandlers так и _extension облегчают апгрейд в случае, если логика не поменялась. Но если нужно будет менять код, то усилий потребуется побольше. К примеру у моего нынешнего клиента может быть 2-3 различных EvenHandlers на метод, т.е. что бы иметь общую картину логики в этом методе, нужно обойти все EvenHandlers и сам метод. Думаю было бы существенно проще, если бы можно было видеть сразу сам метод и весь код из EvenHandlers и _extension в редакторе.
За это сообщение автора поблагодарили: ZVV (2).
Старый 17.12.2015, 13:15   #5
обычно в таких случаях помогает IDE
в аксапте должны быть перекрестные ссылки. но пока через жопу.
обычные правила для разрешения конфликтов имен между локальными и глобальными объектами: в первую очередь ищутся локальные. если их нет, то ищутся глобальные (в данном случае extension)
в ax7 я не знаю способа явно вызвать extension-функцию, если есть метод с таким именем. но должен быть.
судя по моему небольшому опыту работы с extension methods в других IDE с другими языками - не, не усложняет. IDE хорошо показывает что происходит.
Старый 17.12.2015, 13:16   #6
Сообщение от Link Посмотреть сообщение
Да, в ax7 я не знаю другого способа. Но это были беты... Может и доделают в финальной версии.
Старый 17.12.2015, 17:05   #7
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
С учетом того, что для класса можно написать ровно один экстеншен (так как ровно одно имя подпадает под шаблон, не как в C#) мне кажется, единственное для чего можно использовать, как мне кажется, - это для некоторых общих действий для какого-то интерфейса.
Старый 17.12.2015, 17:14   #8
S.Kuskov is offline
S.Kuskov
3,450 / 1792 (66) ++++++++
В статье упоминается ограничение только на окончание метода *_Extension.
Старый 17.12.2015, 17:26   #9
Link is offline
Link
Британский учённый
Аватар для Link
Записей в блоге: 9
Я так понимаю, что не только для класса, а для любого объекта для которого можно создать экстеншн, он может быть только в одном экземпляре. И вся суть заключается в возможности выноса кастомного кода отдельно от стандарта. У меня нет доступа к 7ке, но предположу, что в самом стандарте экстеншены не используются?
По моему опыту экстеншены будут востребованы партнерами и клиентами которые заботятся о легком апгрейде и хотят отделить свои кастомизации от стандартного кода. В целом это оправданно для каких нибудь общих методов, а для специфических решений будут и дальше использовать event handlers.
Однако вопрос удобства анализа кода размазанного по экстеншенам и event hendler остается открытым. Было бы логично иметь доступ сразу ко всему коду объекта в редакторе.
Старый 17.12.2015, 17:33   #10
Link is offline
Link
Британский учённый
Аватар для Link
Записей в блоге: 9
Точно.... хм, тогда получается, что единственный индикатор принадлежности метода это первый параметр. Если нет ограничений на количество классов-расширений для объекта, из этого вытекает, что нет и ограничений на принадлежность. Т.е. в один класс-расширение можно добавить метод для любого поддерживаемого объекта. Интересно как IntelliSense знает какие методы из расширений тянуть?
Старый 17.12.2015, 18:22   #11
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Извиняйте, у меня устаревшие данные.
"The name of the extension class must end with the ten-character suffix _Extension. However, there’s no restriction on the part of the name that precedes the suffix."
mfp: X++ in AX7: Readonly keyword Blog bot DAX Blogs 3 15.12.2015 18:22
mfp: X++ in AX7: Client/Server keywords Blog bot DAX Blogs 23 15.12.2015 09:09
mfp: X++ in AX7: Static event subscription Blog bot DAX Blogs 0 11.12.2015 11:11
mfp: X++ in AX7: The var keyword Blog bot DAX Blogs 43 04.12.2015 10:19
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 19:20.
