Старый 08.08.2014, 04:18   #1
emeadaxsupport: Using the new Keyword search option to create Sales Orders in Dynamics AX 2012 R3
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
In AX 2012 R3 there is a new search feature that you can use to create sales order. With this new feature you can search based on multiple options such as Sales order, Purchase order, and phone number just to name a few. The option that will be discussed in this post is Keyword.
In order to use Keywords in your search you first need to define criteria to be included as keywords. I will use the type of Customer in this example as we working with creating Sales Orders.
  1. Go to Sales and Marketing > Setup > Search and click on Define criteria.
  2. In the Type dropdown list select Customer.
  3. Click new in the menu bar. This will populate a new line where you can select the field you want to enable for keyword search
    1. Some common fields that could be used to search on with keywords are:
      1. AccountNum
      2. City
      3. Name
      4. Address
      5. State
      6. Street
      7. ZipCode
      8. CustGroup
  4. Once the fields are defined click the Refresh button in the menu bar. This essentially saves and activates the criteria you have defined. If you add additional criteria at a later time remember to click the Refresh button.
Now that the search criteria is setup it can be used when creating Sales Orders.
For example let's say that you have criteria setup for Name and you need to create a Sales Order for a school but you cannot remember the actual name or the account number. However you do know that School is part of the name.
When you click to create the Sales Order, select Keyword as the Search by and enter school in the search. The search will return results that have school in any of the fields you have defined in the search criteria. In my case Address is also set as search criteria, and since one of my Customers has School as part of the address, 2 results are displayed.
At this point you can mark the record you want, click Select Customer in the menu bar and continue to create the Sales Order.
Dave B.
Старый 20.08.2014, 09:18   #2
d&m is offline
d&m
MCT
Аватар для d&m
Manzana Group
459 / 186 (7) ++++++
Записей в блоге: 6
понравилось
проверил - удобная фича и даже работает
К примеру, я знаю один из реквизитов товара (код, название, краткое название или какой-то другой).
Раньше (до R3) я должен был:
1. открыть лукап со списком всех товаров
2. выбрать нужный столбец (при это мнужный столбец должен быть в лукапе, как известно, стандартные лукап-ы содержат скудное количество полей)
3. нажать фильтр по полю и ввести искомое значение (со звездочками)
Теперь (в R3):
1. прямо в поле "код номенклатуры" (непосредственно в строке документа, без каких-либо лишних лукапов) вводим известное нам значение (часть кода, названия, краткого названия и т.д.) - без ненавистных для многих пользователей звездочек
2. система фильтрует не по одному столбцу (как раньше), а по преднастроенному списку столбцов из карточки товара (продукта)
3. если по условию найден один товар - он автоматически подставится в строку (раньше нужно было лишний раз кликать на единственную отфильтрованную запись)
4. если по условию найдено более одного товара - откроется отфильтрованный список (поддерживаются номенклатурные аналитики и даже текущие запасы показываются, некий аналог старой доброй формы "Создать строки")
Такие возможности сделаны для клиента и товара.
За это сообщение автора поблагодарили: sukhanchik (4), lev (2), Ivanhoe (3).
Старый 20.08.2014, 10:38   #3
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Хорошее развитие идеи AliasFor
Ivanhoe as is..
lookup, lookup filter, поиск, фильтр
msdyncomm: Microsoft Dynamics AX 2012 R3 for Service Industries demo: Better comply with DCAA rules Blog bot DAX Blogs 0 25.06.2014 05:22
emeadaxsupport: AX Content: Microsoft Dynamics AX 2012 R3 Support for International Financial Reporting Standards (IFRS) Blog bot DAX Blogs 0 24.06.2014 00:13
emeadaxsupport: AX Content: Microsoft Dynamics AX 2012 R3 white papers for Project management and accounting Blog bot DAX Blogs 0 03.06.2014 03:58
emeadaxsupport: AX Content: Make Microsoft Dynamics AX 2012 yours! Blog bot DAX Blogs 0 01.10.2013 00:12
Часовой пояс GMT +3, время: 07:53.
