Старый 23.01.2014, 03:15   #1
Initial parameter default with SysOperation (initParmDefault)
Источник: http://alexvoy.blogspot.com/2014/01/...ault-with.html
With the new SysOperation framework in AX2012 I bumped into a simple question on how to set default value for one parameter in the data contract as I did by using initParmDefault with RunBase class.
Here are two ways to do that: we can initialize any values inside of new() method in the data contract class or, alternatively, override initializeServiceParameter() in the service controller class for a particular data contract type.
The latter always overrides initial default values coming with the data contract.
I used information from this article (in German).
ax2012
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
ax_gfm_framework_team: Default main account with an invalid chart of accounts: locating and fixing Blog bot DAX Blogs 0 24.09.2013 12:11
axmfg: Understanding the default configuration concept for constraint-based products Blog bot DAX Blogs 0 17.07.2013 14:11
emeadaxsupport: "Parameter is missing a value" error running a customized report in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.11.2012 00:12
mscrmblog: This report requires a default or user-defined value for the report parameter ‘Parameter’. To run or subsribe to this report, you must provide a parameter value Blog bot Dynamics CRM: Blogs 1 09.12.2010 09:51
Часовой пояс GMT +3, время: 02:32.
