Старый 03.10.2013, 23:11   #1
lcash: InformationSource login with IE11
Источник: http://blogs.msdn.com/b/lcash/archiv...with-ie11.aspx
I’ve had a few emails on this topics from Microsoft folks who have upgraded to Windows 8.1 with IE11 and haven’t been able to log into http://informationsource.dynamics.com so here a few note on setting the compatibility setting in IE11.
Symptom. If you go to InformationSource and you can’t click the login link
Then follow these steps. Click on the on the settings icon in IE11.
Then click on the Compatibility View settings.
Enter the URL for InformationSource in the “Add this website:” field. Then click the Add button.
You will notice that this will be added to the list of “Websites you’ve added to Compatibility view” as just Dynamics.com. Click Close.
Close the browser and go back to http://informationsource.dynamics.com and you will be able to click the links to login either via LiveID or Microsoft Corporate login.
Cheers
Lachlan
Старый 03.10.2013, 23:11   #2
axsa: InformationSource login with IE11
Источник: http://blogs.msdn.com/b/axsa/archive...with-ie11.aspx
Cheers
Lachlan
lcash: No mouse with Win2008 RTM under Hyper-V Blog bot DAX Blogs 0 12.03.2010 01:06
lcash: Processing OLAP Cubes and AX Companies Blog bot DAX Blogs 0 15.10.2009 07:06
lcash: Using Project Time Sheets setting up the Period Code Blog bot DAX Blogs 0 31.07.2009 06:16
lcash: ProjPost Class compile error Blog bot DAX Blogs 0 24.07.2009 04:20
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 07:29.
