Старый 01.04.2013, 14:11   #1
Empty startupCmd in AX2012
Источник: http://dev.goshoom.net/en/2013/03/em...cmd-in-ax2012/
Recently I had some troubles with one AX2012 environment – startup commands simply didn’t work. AX client started, but that was all.
Debugging showed that startup() method in Info class didn’t receive any command text at all:
After some more investigation I noticed that it does work if I use another configuration file:
The difference between those two configurations is here:
logdir,Text,%USERPROFILE%\Microsoft\Dynamics Ax\Log\company,Text,partition,Text,startupcmd,Text,extracmdline,Text,-Developmentstartupmsg,Text,If extracmdline,Text,-Development (which opens AX directly in Development Workspace) is included, startup commands are ignored. If extracmdline is empty, everything works as usual. It behaves in the same way in both AX2012 and AX2012 R2.
It’s easy to avoid such configuration files… as soon as you know that you should.
Опыт: синхронизация справочников через AIF в AX2012 EVGL DAX: Функционал 14 28.08.2020 17:52
emeadaxsupport: AX2012 Upgrades - Setting a clean AX2012 database to start with the upgrade check-list and not the Initialization check-list. Blog bot DAX Blogs 1 13.02.2013 23:47
emeadaxsupport: Inventory closing differences between AX4.0 and AX2012 using weighted average costing method Blog bot DAX Blogs 0 27.12.2012 19:11
axblog4u: Display Web Image Content in Forms using Dynamics AX2012 Blog bot DAX Blogs 0 28.05.2012 19:12
emeadaxsupport: AX2012 and AX2009 or AX4 side by side - AOS performance counters overwritten Blog bot DAX Blogs 0 13.03.2012 18:11
Часовой пояс GMT +3, время: 00:21.
