Старый 07.09.2012, 07:11   #1
emeadaxsupport: RadipStart Connector for Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
Hello!
If you are working with the RapidStart Connector you may run into the following message:
The reason you are seeing this error is becuase the connector service required to configure an on-premise instance of Microsoft Dynamics AX 2012 instance using RapidStart Services has recently been updated. In order to proceed past this error you’ll need
the most updated version. For existing installs of the connector service it is recommended that you update them to this most current version. Review the release notes included in the download for more details on this process.
Please install the most updated version from this link :
https://mbs.microsoft.com/downloads/...nnectorService
The Dynamics AX 2012 download page also has a note about this update and link to the page below. A PartnerSource login will be needed to access this page:
https://mbs.microsoft.com/partnersou...micsax2012.htm
You can also learn more about any upcoming changes from the RapidStart team blog :
https://community.dynamics.com/produ...g/default.aspx
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 21:12.
