Старый 10.02.2012, 12:11   #1
palleagermark: Preventing client crashes when applying new event handlers
Источник: http://palleagermark.blogspot.com/20...-applying.html
Almost every time I create a new pre- or post-event handler and try to use use it immediately on a new Event Handler Subscription, the AX client crashes.
You can prevent these crashes by saving the event handler class and restoring it, before addressing it on a new Event Handler Subscription. Restore is placed on right click / Restore.
Event ID: 110 и Event ID: 117 Object Server 01: The database reported (session 1 (-AOS-)): [Microsoft][SQL Native Client]Communication link failure. The SQL statement was: "" Poleax DAX: Администрирование 0 18.05.2011 17:08
emeadaxsupport: Project Server Integration–the list of event handlers created by Dynamics AX synchronization Blog bot DAX Blogs 0 18.04.2011 23:11
haditeo: Is it possible to register different event handlers in only one assembly to be registered in Dynamics CRM Plugin ? Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 12:35.
