Старый 22.04.2011, 17:11   #1
equalized: Dynamics ax take screenshots from FormControls
Источник: http://blog.equalized.be/2010/11/dyn...-formcontrols/
Hi all,
Here is a little code snippet for you to take screen shots within a Dynamics Ax client.
public void run(FormControl _control)
    str                         SaveToFileName;
    System.Drawing.Bitmap           bitmap;
    System.Drawing.Graphics        graphics;
    System.Windows.Forms.Screen primaryScreen;
    System.Drawing.Rectangle       bounds;
    int                                       x, y, k, l;
    System.Int32                         width;
    System.Int32                         height;
    #define.FileName('DynamicsAx_Screenshot.png')
    try
        // 5 for the My Documents folder
        SaveToFileName  = strfmt(@"%1\%2",WinApi::getFolderPath(5),#FileName);
        primaryScreen   = System.Windows.Forms.Screen::get_PrimaryScreen();
        bounds          = primaryScreen.get_Bounds();
        [x, y, k, l]    = WinApi::getWindowRect(_control.hWnd());
        width           = _control.widthValue();
        height          = _control.heightValue();
        // TwC: used API CLRObject
        // BP Deviation Documented
        bitmap          = new System.Drawing.Bitmap(width,height);
        graphics        = System.Drawing.Graphics::FromImage(bitmap);
        graphics.CopyFromScreen(x,y,0,0,bitmap.get_Size());
        bitmap.Save(SaveToFileName, System.Drawing.Imaging.ImageFormat::get_Png());
    catch
        error("The file could not be saved"); // TODO make label
This snippets uses the size of your control and the position on your screen to create the screenshot
Последний раз редактировалось Poleax; 22.04.2011 в 17:27. Причина: код
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 14:52.
