Старый 20.04.2011, 16:11   #1
Ronni Mattsson: Issue with tracing kerberos when setting up Role Center use the Kerberos event logging
Источник: http://blogs.msdn.com/b/microsoft_dy...t-logging.aspx
When setting up Role Center sometimes kerberos can be a little tricky, using the following registry changes has help me allot to track down the issues. Normally I use this on all the servers involved with Role center.
Microsoft Windows 2000, Windows Server 2003, and Windows Server 2008 offer the capability of tracing detailed Kerberos events through the event log mechanism. You can use this information when you troubleshoot Kerberos
Enabling Kerberos Event Logging on a Specific Computer
1. Start Registry Editor.
2. Add the following registry value:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\Kerberos\Parameters
Registry Value: LogLevel
Value Type: REG_DWORD
Value Data: 0x1
If the Parameters subkey does not exist, create it.
NoteRemove this registry value when it is no longer needed so that performance is not degraded on the computer. Also, you can remove this registry value to disable Kerberos event logging on a specific computer.
3. Quit Registry Editor. The setting will become effective immediately on Windows Server 2008, on Windows Vista, on Windows Server 2003, and on Windows XP. For Windows 2000, you must restart the computer.
You can find any Kerberos-related events in the system log.
....Happy hunting....
Ronni Mattsson: AX 2012 and the kerberos story Blog bot DAX Blogs 0 20.04.2011 16:11
emeadaxsupport: How can the Role Center be individually turned off? Blog bot DAX Blogs 0 14.07.2010 01:05
fed: Tracing in Dynamics AX 4 and 2009 Blog bot DAX Blogs 0 10.03.2010 20:05
Microsoft Dynamics AX 2009 White Paper: Tracing Role Center KPIs Vadik DAX: База знаний и проекты 0 16.01.2010 12:30
Solutions Monkey: Kerberos configuration for Clients accessing Role Center from outside of intranet Blog bot DAX Blogs 0 21.05.2009 18:05
Часовой пояс GMT +3, время: 08:56.
