Старый 31.07.2009, 00:06   #1
axcoder: Mental framework
Источник: http://axcoder.blogspot.com/2009/07/...framework.html
Review of the book “Managing your supply chain using Microsoft dynamics ax 2009”
After about 5 years of Ax development I’ve recognized that the model of Dynamics Ax functionality which I have in my brain is like photosynth – some areas, I worked with, covered by consistent pictures, but others are represented by random shots without high level overview.
The majority of existing materials about Ax – like trainings, documentation, so on, use “hands on” approach – little introduction and very detailed description using screenshots, particular sequences of steps in term of buttons, etc.
So I feel that there is a gap between short intros of documentation and very detailed contents (for example Russian docs contains of 2 volumes >1000 pages each).
That’s why I was very interested when Dr. Scott Hamilton sent me kindly the book, which was written to give “mental framework for putting together the details” learned from various sources . So below are my impressions.
The book contains 426 pages, and most of them are text description of Ax functionality: no screenshots, no concrete steps – just text, tables and business process flowcharts. Thus, the information density is quite high.
The book consists of 15 chapters, each dedicated for some functional area. All chapters are in scope of SCM (you can see TOC at Amazon). Each chapter contain description of a functional area, case studies and executive summary.
New features of Ax2009 (such as sites and purchase requisition) are reflected.
What I like about the book
  • The book met my expectations about abstraction level it have no redundant details, which can be obtained from products docs and training, and contains enough for making mental model of SCM modules.
  • There are lots of tables showing how ax behavior depends on parameter combinations – it helps to understand the space of different implementation scenarios.
  • As I mentioned before the most important features of ax2009 are described
What can be done better
  • Some case studies are very brief – I’d prefer to include more detailed business scenarios and more implementation details. (But maybe I should read some book about common business practice instead – could you recommend me such a book?)
Overall impression
I’d buy the book if I haven’t one. I recommend it for everybody who want to have a consistent view of Ax SCM functionality.
PS. there is also a new book by Dr. Hamilton - Managing Lean Manufacturing using Microsoft Dynamics AX 2009
Старый 31.07.2009, 09:09   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Автор меня попросил спросить у комьюнити, насколько нужен перевод такой книжки на русский язык
Старый 31.07.2009, 09:58   #3
чел здорово ошибается по поводу "большой детализации" в русских доках.
Но с подходом абсолютно согласен.
возможно, мой английский недостаточно хорош.
но я не понял - сообщение про старую книгу? тогда она уже переведена http://www.ozon.ru/context/detail/id/2430490/
но, насколько я помню, там ничего по функциональности ax2009 не было.
А как понимать это "also"?
also вот вам ссылка на то, о чем мы говорили?
или also есть и другая книга, о которой здесь не говорили, но она тоже по теме?
перевод на русский книг Гамильтона - нужен.
Я не в восторге от переводов его книг, считаю, что там очень много воды. И очень много несовпадений и с Аксаптой, и с Навижином. Возможно, это эффект перевода.
Но в них действительно содержатся ответы на вопросы "почему так сделали".
В этом его книги уникальны.
Поэтому перевод книги Гамильтона должен быть, на мой взгляд.
Старый 31.07.2009, 10:10   #4
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Чел - это я - считает, что то, что описано, описано на уровне скриншотов и нажатий на кнопки, а не концепции.
Чел описывает новую книжку, в которой есть про Ax2009. Она еще не переведена и автор интересуется, насколько она нжна на российском рынке.
Also относится к новой книжке по Lean Manufacturing. Чел получил от автора ссылку на нее (кстати, интересно, там учитывается только вышедший модуль или это как-то по другому организовано?)
Спасибо
За это сообщение автора поблагодарили: Kabardian (3).
Старый 31.07.2009, 10:20   #5
Чел - это я
я думал, что ты просто опубликовал сообщение от хамильтона.
извини, круто ошибся. реально, извини.
а вот с этим ап-солютно согласен.
Нужна.
Только переводить ее должны люди, которые знают Аксапту, чтобы не получилось "как раньше".
Как выяснилось, я и по-русски плохо понимаю
новая книжка по Lean Manufacturing - это та же самая "новая книжка, в которой есть про Ax2009"? Или это какая-то другая новая книжка?
Старый 31.07.2009, 10:23   #6
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Ничего - все нормально
Это две разные книжки:
Старый 31.07.2009, 10:26   #7
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Кстати, что можно почитать не привязанное к конкретно аксапте. В смфсле про бизнес проуессы обычно поисходящие на западе при покупке продаже производстве и т.д.
Старый 31.07.2009, 10:27   #8
miklenew is offline
miklenew
Аватар для miklenew
1C
1,688 / 438 (18) +++++++
Когда то искал Управление цепочками поставок под 3.0 не нашёл, даже в электронке.
Всё раскупили. Тираж походу маленький был.
Если будет перевод обязательно почитаю.
Энергия молодых и неравнодушных способна изменить мир к лучшему.
За это сообщение автора поблагодарили: belugin (1).
Старый 31.07.2009, 14:17   #9
apanko is offline
apanko
1,164 / 139 (7) +++++
По моему на западе этим занимается организация APICS, соотвественно и читать надо бы ее книги (http://www.apics.org/)
За это сообщение автора поблагодарили: belugin (3).
Старый 01.08.2009, 17:20   #10
Kabardian is offline
Kabardian
Талантливый разгвоздяй
Аватар для Kabardian
424 / 338 (12) ++++++
Записей в блоге: 14
Книги Скотта Гамильтона по SCM
Оказывается, Скотт Гамильтон написал книги по SCM почти по всем версиям AX:
Managing Your Supply Chain Using Microsoft Navision
Managing Your Supply Chain Using Microsoft Axapta
Managing Your Supply Chain Using Microsoft Dynamics AX
Managing Your Supply Chain Using Microsoft Dynamics AX 2009
Старый 03.08.2009, 10:47   #11
Gustav is offline
Gustav
Аватар для Gustav
SAP
1,858 / 1152 (42) ++++++++
Записей в блоге: 19
Сообщение от Kabardian Посмотреть сообщение
И некоторые даже уже давно переведены на русский:
Управление цепочками поставок с Microsoft Navision
Управление цепочками поставок с Microsoft Axapta
Старый 06.08.2009, 14:57   #12
GM2005 is offline
GM2005
выдержка из книги Scott Hamilton, Managing Lean Manufacturing Using Microsoft Dynamics AX 2009 (http://msdynamicsworld.com/story/bil...ng-using-micro)
Старый 07.08.2009, 12:31   #13
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Да, я тоже считаю, что это очень хорошая книга. Правда я так пока до нее не добрался, поэтому это только мои предположения.
Я все еще пока "мучаю" APICS. Интересно, но уж слишком много разных бизнес-процессов, и когда ты с ними напрямую в данный момент не работаешь, через месяц уже тяжело что-то вспомнить.
Но, наверное, общие понятия она таки дает.
А Гамильтон рулит
Старый 07.08.2009, 18:28   #14
apanko is offline
apanko
Толковая? Стоит брать?
И какая конкрентно?
Старый 07.08.2009, 22:48   #15
kashperuk
Сообщение от apanko Посмотреть сообщение
И какая конкрентно?
Introduction to Materials Management, Sixth Edition
За это сообщение автора поблагодарили: apanko (2).
ax2009, download, книга, производство, управление запасами, управление проектами, управление цепочками поставок, загрузка
palleagermark: Intelligent Data Management Framework For Microsoft Dynamics AX (Pre-Release) Blog bot DAX Blogs 0 01.07.2009 00:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: The Send Framework Blog bot DAX Blogs 0 05.10.2007 23:31
Inside Dynamics AX 4.0: RunBase Framework Extension Part IV Blog bot DAX Blogs 0 02.10.2007 04:49
Inside Dynamics AX 4.0: RunBase Framework Extension Part I Blog bot DAX Blogs 0 30.09.2007 09:20
Часовой пояс GMT +3, время: 04:14.
