Старый 03.01.2009, 18:36   #1
25,751 / 851 (80) +++++++
axaptapedia: Load Web Documents
Источник: http://www.axaptapedia.com/Load_Web_Documents
Summary:
Loading web documents is easy using Microsoft .NET Framework in Dynamics AX. All necessary classes are implemented in System.IO Namespace and ready to use in Dynamics AX. For example reading the HTML document from Axaptapedia.com can be done in this way:
System.Net.WebRequest request = System.Net.WebRequest::Create("http://www.axaptapedia.com");
System.Net.WebResponse response;
System.IO.StreamReader reader;
System.IO.Stream stream;
System.String line;
response = request.GetResponse();
stream = response.GetResponseStream();
reader = new System.IO.StreamReader(stream);
line = reader.ReadLine();
while(line != null)
info(line);
reader.Close();
==Loading XML document==
While XML is the default industry standard for data exchange, it is simple to load published XML documents. News Feeds are published as XML documents that are interpreted by a browser or mail client like outlook to provide a convenient user interface. To handle XML documents add the System.Xml namespace at the AOT.
// MSDN RSS feed
System.Net.WebRequest request = System.Net.WebRequest::Create("http://www.microsoft.com/feeds/msdn/en-us/rss.xml");
System.String xmlFeed;
System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
System.Xml.XmlNodeList nodeList;
System.Collections.IEnumerator titleEnum;
System.Xml.XmlNode title,value;
// Load
xmlFeed = reader.ReadToEnd();
reader.Close();
// Parse and show feed titles
doc.LoadXml(xmlFeed);
nodeList = doc.SelectNodes("//title"); // XPath expression, all titel elements
titleEnum = nodeList.GetEnumerator();
while(titleEnum.MoveNext())
title = titleEnum.get_Current();
value = title.get_FirstChild(); // text node is first child of parent title element
info(value.get_Value());
[[Image:Rssfeedtitle.PNG‎]]
[[Category:.NET Development]]
Старый 03.01.2009, 23:50   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
1.
public static void TEST_DownloadString (Args _args)
    System.Net.WebClient webClient = new System.Net.WebClient();
    info(webClient.DownloadString('http://axaptapedia.com'));
2.
static void Job8(Args _args)
    XmlDocument doc = new XMLDocument();
    XMLElement element;
    doc.load(@'http://www.axaptapedia.com/index.php?title=Special:Recentchanges&feed=rss');
    nodeList = doc.selectNodes(@'//item');
    for(element = nodeList.nextNode(); element; element = nodeList.nextNode())
        info(element.getNamedElement('title').text());
За это сообщение автора поблагодарили: mazzy (2), gl00mie (2), alex55 (1), kpoxa (1).
Consuming "CustomerService" Web Service Blog bot DAX Blogs 0 25.01.2008 15:10
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Dynamics AX: Web 2.0 Workgroup - A network of Web 2.0 resources Blog bot DAX Blogs 0 28.10.2006 16:40
Solutions Monkey: EP Web Part connection Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 04:55.
