Старый 10.11.2006, 01:36   #1
casperkamal: Using SysDictClass::as
Источник: http://casperkamal.spaces.live.com/B...CD63!164.entry
                   SysDictClass has a function called SysDictClass::as(Object _class, classId _classId), this  function serves the purpose of using an object instance only if it extends or implements a specified super class.It can turnout to be very useful when you have cases like you want a particular function to be called only if the object received as argument implements a certain Interface
For Example
You have an Interface Class  "mercedes"  which has an interface method like "microcomputer". you want the function microcomputer to be executed only when the object you received has implemented the mercedes interface, in these situation where decision is a runtime based one the above specified function would serve handy
Class myClass(Object _car)
       Mercedes mercedes =  SysDictClass::as(_car, classnum(mercedes));
         if (mercedes)
              mercedes.microcomputer();
............lala lal laaaha.....
casperkamal: A small addition to creation of Table throug x++ code in Dynamics Ax Blog bot DAX Blogs 0 03.04.2007 23:11
casperkamal: Customized Google Search for DAX Blog bot DAX Blogs 0 31.01.2007 21:00
casperkamal: Sending Emails from Ax Blog bot DAX Blogs 0 28.11.2006 14:10
casperkamal: Code Access security Blog bot DAX Blogs 0 10.11.2006 01:36
Часовой пояс GMT +3, время: 12:15.
