organicax: Stop conditions Workflow line manager = 2
Источник: https://organicax.com/2016/12/02/sto...ine-manager-2/
============== In a previous post we had a look at the stop condition where the line manager is = 1. If you want two levels of approval then one option you have is to use line manager = 2. This will allow you to have two levels based on the condition set on the hierarchy options Assign to all users retrieved. Here is a quick overview. AX2012 CU11 Cheers Lachlan Filed under: Workflow Источник: https://organicax.com/2016/12/02/sto...ine-manager-2/
organicax: Stop conditions Workflow line manager = 1
Источник: https://organicax.com/2016/12/02/sto...ine-manager-1/
============== If you are setting up workflow and using the managerial hierarchy then you will have to play with the stop conditions as the rules for what person is returned for approval. One of the stop conditions would be line manager = 1. This will stop at the manager one level up. Here is a quick overview. AX2012 CU11 Cheers Lachlan Filed under: Workflow Источник: https://organicax.com/2016/12/02/sto...ine-manager-1/
