emeadaxsupport: Dynamics AX 2012 Enterprise Portal: range on dataSetLookup()
Источник: http://blogs.msdn.com/b/axsupport/ar...setlookup.aspx
============== As described here Configuring the Lookup for a Data Set Field [AX 2012] you can change how lookup look like. What you can also do you can range to the lookup to show i.e. only rooms which are in service. Following X++ shows how to achieve this: void dataSetLookup(SysDataSetLookup sysDataSetLookup) { List list = new List(Types::String); Query query = new Query(); QueryBuildDataSource queryBuildDataSource; QueryBuildRange qbr; // Add the table to the query. queryBuildDataSource = query.addDataSource(tableNum(FCMRooms)); // Specify the fields to use for the lookup. list.addEnd(fieldStr(FCMRooms,RoomName)); list.addEnd(fieldStr(FCMRooms,RoomType)); list.addEnd(fieldStr(FCMRooms,InService)); // Supply the set of lookup fields. sysDataSetLookup.parmLookupFields(list); // Specify the field that is returned from the lookup. sysDataSetLookup.parmSelectField('RoomName'); //add the range qbr = queryBuildDataSource.addRange( fieldnum(FCMRooms, InService)); qbr.value(NoYes::Yes); //if we don’t want user to be able to change range we need to lock it qbr.status(RangeStatus::Locked); // Pass the query to the SysDataSetLookup so that the query is used. sysDataSetLookup.parmQuery(query); } We need to lock the range in order user is unable to change the range. Otherwise if user in search will specify RoomName “Cubicle 8” (when inService == No) it will still appear because the range will be simply overwritten. Источник: http://blogs.msdn.com/b/axsupport/ar...setlookup.aspx
Опции просмотра | |
