ax.docentric: Comment on Configure SharePoint Online integration in D365FO OneBox by Miha Vuk
Источник: https://ax.docentric.com/configure-s...#comment-10869
============== In reply to Omar Frassinotti. Hi Omar, This article describes how to establish the trust between Azure application called Microsoft Dynamics ERP (created by Microsoft) with ID 00000015-0000-0000-c000-000000000000 and your SharePoint. Up to April 2022 all local OneBoxes were using this ID and it still works if you follow our steps. However you can create your Azure application and use its ID, but then you have to adjust the scripts. If you have an already provisioned environment I would recommend the following:
