Старый 16.08.2019, 02:39   #1
How to debug Workflow in D365 without access to Batch.exe
Источник: http://alexvoy.blogspot.com/2019/08/...5-without.html
Correct me if I am wrong, but there is no specific article https://docs.microsoft.com about debugging custom Workflow in D365.
So, once I bumped into necessity to test my custom Workflow classes, I found myself unlucky not having admin rights fot Batch.exe (as described here https://ax.docentric.com/debug-workf...nd-operations/)
Next search results (in particular this one https://thwidmer.wordpress.com/categ...x-2012/page/2/) brought me to the following steps.
I stopped DynamicsAxBatch, which execute actual batch processing in D365.
I added the following simple class and and a menu item button to a form.
class CDPWFDebuggerActive
static public void main(Args _args)
SysWorkflowMessageQueueManager::runStatic(conNull());
Now I run it by the button to execute batch processing in step-by-step mode, and it perfectly hits my breakpoints inside of Workflow handlers once I attached to the standard IIS process.
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 5.0 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:51
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 4.0 Service Pack 3 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:28
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 23:02.
