crmtipoftheday: Tip #1264: Subscribe to AD changes using Flow
Источник: https://crmtipoftheday.com/1264/subs...es-using-flow/
============== My flowbies! I want to trigger a Flow based on someone being added to an Azure AD Group. This doesn’t appear to be possible currently, as the Azure AD connector has no triggers. Am I correct?Hold my beer Microsoft Graph API contains the subscription feature where you can create subscriptions where a listener application receives notifications when the changes occur in the specified resource. The process involves the following steps:
Notification endpoint Flow Creating a subscription requires a notification endpoint that must satisfy certain validation requirements, namely return a validationToken passed as a query parameter. ![]()
Creating app in Azure AD is very straightforward – just follow the documentation. Since we are subscribing to the group, we need to add Group.ReadAll permission for Graph API. Subscriber Flow I wish I could claim the technique of creating a subscription using Flow but the formidable John “Flow Ninja” Liu described the technique over a year ago :O. Just follow the steps and you’ll be all set. For a change, I decided to use Postman. The easiest way to deal with authentication is to create a collection and set all requests within the collection to inherit the authentication token. ![]() Once Postman has a token, sending request to subscribe to groups changes is a breeze: ![]() Testing After adding a user to one of the groups in Azure AD, you’ll see two (hopefully) successful runs for the notification Flow. First one is a validation run (you can drill into it and check the validation token that was passed in). Second one is the real McCoy containing the following data in HTTP request body: [ { "changeType": "updated", "clientState": "MaSekreet", "resource": "Groups/deadbeef-dead-beef-dead-beef00000075", "resourceData": { "@odata.type": "#Microsoft.Graph.Group", "@odata.id": "Groups/deadbeef-dead-beef-dead-beef00000075", "id": "deadbeef-dead-beef-dead-beef00000076", "organizationId": "deadbeef-dead-beef-dead-beef00000077", "eventTime": "2019-05-07T11:08:15.4245258Z", "sequenceNumber": 636928240954245200, "members@delta": [ { "id": "deadbeef-dead-beef-dead-beef00000088" } ] }, "subscriptionExpirationDateTime": "2019-05-07T15:37:48+00:00", "subscriptionId": "deadbeef-dead-beef-dead-beef00000069", "tenantId": "deadbeef-dead-beef-dead-beef00000096" }, { "changeType": "updated", "clientState": "MaSekreet", "resource": "Groups/deadbeef-dead-beef-dead-beef00000075", "resourceData": { "@odata.type": "#Microsoft.Graph.Group", "@odata.id": "Groups/deadbeef-dead-beef-dead-beef00000075", "id": "deadbeef-dead-beef-dead-beef00000076", "organizationId": "deadbeef-dead-beef-dead-beef00000077", "eventTime": "2019-05-07T11:08:15.4245258Z", "sequenceNumber": 636928240954245200 }, "subscriptionExpirationDateTime": "2019-05-07T15:37:48+00:00", "subscriptionId": "deadbeef-dead-beef-dead-beef00000069", "tenantId": "deadbeef-dead-beef-dead-beef00000096" }]That’s a lot to digest but members@delta is the magic data that tells us that a user has been added to the group. I’ll save digesting this json for another day. Here you go, Andy! Cover photo by unsplash-logoLance Anderson Источник: https://crmtipoftheday.com/1264/subs...es-using-flow/
