Старый 19.03.2019, 23:13   #1
a33ik: AIF: User is not authorised for this port.
Источник: http://daxonline.org/1645-aif-user-i...this-port.html
Error: User is not authorised for this port.
Solution 1:
Change the owner of the file to someone registered as user in ax.
File -> Properties -> Security -> Advanced -> Owner / Change
Solution 2:
Edit inbound port. Deactivate it. File system adapter -> Configure -> Use default owner for Administrators group (check) -> Select AX user in drop down.
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
stoneridgesoftware: User Personalization in Dynamics NAV: Work Smart, Not Hard Blog bot NAV: Blogs 0 13.04.2018 21:14
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
KB 3023315"User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)" error when adding a record through Application Integration Framework (AIF) for a non-ad Vadik DAX: База знаний и проекты 0 13.01.2015 15:54
Часовой пояс GMT +3, время: 00:32.
