			ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 2 – Format.
			Источник: https://ievgensaxblog.wordpress.com/...part-2-format/
			============== In this blog post we will create new Format. It represents document schema and is used to parse it. Go to Organization administration > Workspaces > Electronic reporting, select Data Model created in the previous post and create new configuration: ![]() In the format designer Add root –> File: ![]() Add sequence and set delimiter to New line – Windows (CR LF). It will tell ER that file has lines split by CR LF. It is possible to select CR for Mac or LF for Linux or specify a custom delimiter. ![]() Add new sequence. This sequence will represent lines. Set Multiplicity to “One many” to say that at least one line is required. ![]() Add another sequence. It will represent individual lines. Set delimiter to ‘,’, to split fields by comma. Use another delimiter, if required. ![]() Add 3 fields: ![]() In the end you should have format like this: ![]() In the next post we will map format to model and test it! Источник: https://ievgensaxblog.wordpress.com/...part-2-format/
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
