Старый 01.11.2018, 22:18   #1
a33ik: Uninstall a model from UAT/PROD
Источник: http://daxonline.org/1629-uninstall-...-uat-prod.html
To delete the model, which was installed on the UAT/PROD environment via LCS you need:
  1. Create a file that is named ModuleToRemove.txt.
  2. In the file, put the name of each module that you want to remove on a separate line.
  3. Create a valid deployable package, and put the ModuleToRemove.txt file in the package\AOSService\Scripts folder.
  4. Install the deployable package.
You do not need to delete all the components from a model and will create a deployable package out of it, you need only to put a file with the model name for deleting. Keep in mind that your model should not have models dependent on it, as this could lead to system errors.
Source -> https://docs.microsoft.com/en-us/dyn...ll-a-package-1
a33ik: How to import project from one model to another (D365FO) Blog bot DAX Blogs 0 26.12.2017 19:11
stoneridgesoftware: Dynamics 365 for Operations: How to Create a New Model Blog bot DAX Blogs 0 11.02.2017 01:11
Leon's CRM Musings: Dynamics CRM Licensing for DEV, UAT and PROD Blog bot Dynamics CRM: Blogs 0 18.08.2013 21:15
Часовой пояс GMT +3, время: 22:49.
