Старый 03.07.2018, 04:33   #1
alirazazaidi: Data Manipulation in Dynamics Ax 2012- Array as Extended Data Type
Источник: https://www.tech.alirazazaidi.com/da...ded-data-type/
I found a array based field in TSTimesheetLineWeek table, Field TSWeeklyHours
Now challenge is to enabled field based on Array. For example need to disabled on day 6.
Following code snippet help me to enabled disabled fields generated on the base of array extended Type
TSTimesheetLineWeek_ds.object(fieldId2Ext(fieldNum(TSTimesheetLineWeek, Hours), 6)).allowEdit(false);
Reference :
https://msdn.microsoft.com/en-us/library/aa675074.aspx
https://docs.microsoft.com/en-us/pre...92700(v=ax.50)
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
Часовой пояс GMT +3, время: 20:37.
