a33ik: AIF document service jobs/info
Источник: http://daxonline.org/1616-aif-docume...jobs-info.html
============== Job to execute/process messages static void AifTestRun(Args _args){ // inbound messages new AIFGatewayReceiveService().run(); new AIFInboundProcessingService().run(); // outbound messages new AIFOutboundProcessingService().run(); new AIFGatewaySendService().run(); info("done");}Example of "read" outbound:static void AifTest(Args _args){ AxdSendContext axdSendContext = AxdSendContext::construct(); AifEntityKey aifEntityKey = AifEntityKey::construct(); Map keyData; AifConstraintList aifConstraintList = new AifConstraintList(); AifConstraint aifConstraint = new AifConstraint(); VendInvoiceInfoTable vendInvoice; XMLDocPurpose _xMLDocPurpose = XMLDocPurpose::Original; AifSendMode _aifSendMode = AifSendMode::Async ; select firstOnly vendInvoice order by RecId desc where vendInvoice.PurchId == 'BHF-000060'; keyData = SysDictTable::getKeyData(vendInvoice); aifEntityKey.parmTableId(vendInvoice.TableId); aifEntityKey.parmRecId(vendInvoice.RecId); aifEntityKey.parmKeyDataMap(keyData); axdSendContext.parmXMLDocPurpose(_xMLDocPurpose); axdSendContext.parmSecurity(false); aifConstraint.parmType(AifConstraintType::NoConstraint) ; aifConstraintList.addConstraint(aifConstraint) ; AifSendService::submitDefault( classnum(VendInvoiceService), aifEntityKey, aifConstraintList, _aifSendMode, axdSendContext.pack()); info("done");}Example of "find" outbound. Export all records by query:static void ABIVend(Args _args){ VendTable vendTable; AxdSendContext axdSendContext = AxdSendContext::construct(); AifEntityKey aifEntityKey = AifEntityKey::construct(); AifConstraintList aifConstraintList = new AifConstraintList(); AifConstraint aifConstraint = new AifConstraint(); AifEndpointList endpointList; AifActionId actionId; Query query; QueryBuildDataSource qbds; query = new Query(queryStr(AxdVendTable)); AxdSend::removeChildDs(query); actionId = AifSendService::getDefaultSendAction(classnum(VendVendTableService), AifSendActionType::SendByQuery); aifConstraint.parmType(AifConstraintType::NoConstraint); aifConstraintList.addConstraint(aifConstraint) ; endpointList = AifSendService::getEligibleEndpoints(actionId, aifConstraintList); AifSendService::SubmitFromQuery(actionId,endpointList,query,AifSendMode::Async);}In case of changes and adding new services:
For error System Administration -> Periodic -> Services and Application Integration Framework -> Exceptions // Note: For debugging \Classes\AifInboundProcessingService\runAsUserInPartition File name generation for a file adapter \Classes\AifFileSystemSendAdapter\getNewOutFileName Источник: http://daxonline.org/1616-aif-docume...jobs-info.html |
