Старый 14.06.2018, 07:17   #1
daxmusings: Accidental Code Extensions
Источник: http://feedproxy.google.com/~r/Dynam...xtensions.html
Ok, I'll preface this by saying I'm very much aware that the standard X++ code in platform and application has this issue too. Thanks for letting me know :-) But as the saying goes: do as I say - not as I do...
With that out of the way... Going back in time, the 7.0 X++ language supported extension methods like C#. You create a new class with any name, but ending in _Extension. Then, you can add a new public static method, and the first parameter is the object you're extending.
So for example:
static class MyExtensions_Extension
public static void foo(PurchTable _purchTable)
public static void bar(SalesLineType _salesLineType)
This class adds extension method foo() to the PurchTable table and method bar() to the SalesLineType class. This feature is now less used due to the [ExtensionOf()] "augmentation" class paradigm where you can have instance method, add member variables, access protected members, etc. However, the original extension method feature still exists, and in fact many people accidentally use it!
The issue happens when adding both extension methods and event handlers in the same class. In theory this sounds great - you have all your extensions in one place. For example:
static class MyPurchTableExtensions_Extension
public void foo(PurchTable _purchTable)
[DataEventHandler(tableStr(PurchTable), DataEventType::Inserting)]
public static void HandlePurchInserting(Common sender, DataEventArgs e)
This works as expected - a new method foo() is added to PurchTable, and you're handling the inserting event. However, the unintended consequence is that you are ALSO adding a new method HandlerPurchInserting(DataEventArgs e) on the Common object! The compiler does not discriminate the fact that you have a handler attribute on that method. All it sees is you're adding a static method in an _extension class, with one or more arguments.
So... How many methods have you accidentally added to Common, XppPrePostArgs, FormRun or FormControl? :-)
daxmusings: The Overall Concept of Extensions in AX 7 Blog bot DAX Blogs 0 14.09.2017 13:11
sertandev: AX7 Extensibility Overview – Part 2 : Code extensions Blog bot DAX Blogs 0 28.08.2017 19:11
daxmusings: The Overall Concept of Extensions in AX 7 Blog bot DAX Blogs 0 04.10.2016 12:11
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 06:46.
