Art Of Creation: Large and strange font sizes in menus for Dynamics AX 2012 on remote sessions
Источник: http://www.artofcreation.be/2018/02/...mote-sessions/
============== Hi all! When you open a Dynamics AX 2012 client (RTM/FP/R2/R3) on a remote session it sometimes look pretty weird. Font sizes are all over the place and overall it doesn’t look that great. See for example in the following screenshot: ![]() You can get better results by changing the properties of the shortcut if you check the checkbox Disable display scaling on high DPI settings on the Compatibility tab. ![]() The result is better but still not entirely accurate: ![]() You can get the best results by changing the display settings on you host system (so the PC or laptop you are working on). I have Windows 8.1 but you should find a similar setting on other versions of Windows in the Display section of the Control panel. Microsoft recommends 125% scaling by default, but I prefer to set it at 100%. Setting it to 100% will also give you the best results for Dynamics AX 2012 in remote sessions. So, on your system, change the setting to 100% as seen in the following screenshot. ![]() This property will only be active after you sing off and sign in again, so do that also. If you connect to a remote session now, you will see that the scaling of the text in Dynamics AX 2012 is now accurate. This will improve your experience and your screenshots. ![]() Источник: http://www.artofcreation.be/2018/02/...mote-sessions/
