dynamicsaxbi: Publish the Entity Store database on Azure SQL Server
Источник: https://blogs.msdn.microsoft.com/dyn...re-sql-server/
============== This step involves deploying an Entity Store database onto your Azure SQL Server created in the previous step. Before you proceed, be sure to process the Aggregate Measurements using the Dynamics 365 Administrative Tools to populate the database. Use the following steps to seed the Entity Store database with sample data for the Application Suite's... Источник: https://blogs.msdn.microsoft.com/dyn...re-sql-server/
