emeadaxsupport: DIXF – AX 2012 R3 – KB3216243 – Assume service is on active SQL Server node
Источник: https://blogs.msdn.microsoft.com/axs...l-server-node/
============== We recently released a DIXF Application Hotfix for AX 2012 R3 that you may want to take a look at if you are running a Clustered configuration / AlwaysOn configuration: The changes in the hotfix introduce a new option of “Assume service is on active SQL Server node” on the “Data import/export framework parameters” form.... Read more Источник: https://blogs.msdn.microsoft.com/axs...l-server-node/
