Старый 02.12.2016, 04:21   #1
organicax: Vendor Invoice line amount for approval in workflow
Источник: https://organicax.com/2016/12/01/ven...l-in-workflow/
When you are setting up a workflow for use with the vendor invoice line and you want to check the amount to have a condition or decision on where it needs to go. Then you might want to check the fields you are working with. There is one called Amount and one called Net Amount. Unless you are working with project you probably want to base you workflow on the Net Amount field.
Here is a quick overview.
AX2012 CU11.
Cheers
Lachlan
Filed under: Accounts payable, Workflow
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Nav developer: Table Information including Index information (Usage, Blocks and Reads) Blog bot Dynamics CRM: Blogs 0 25.08.2009 19:34
NAV Sustained Engineering Team Blog: Index Usage Query Blog bot Dynamics CRM: Blogs 0 26.02.2008 12:29
Часовой пояс GMT +3, время: 03:49.
