organicax: Vendor hold release date
Источник: https://organicax.com/2016/10/09/ven...-release-date/
============== If you are looking at putting vendors on hold there are a few different type of holds. When you set these you can specify the vendor hold release date. You can then use it to review those holds and check which ones you might be able to take off hold. Here is a quick overview. AX2012 R3 CU11 Cheers Lachlan Filed under: Accounts payable ![]() Источник: https://organicax.com/2016/10/09/ven...-release-date/
