Старый 04.10.2016, 05:35   #1
organicax: Operations infrastructure inquiry – AX7
Источник: https://organicax.com/2016/10/03/ope...e-inquiry-ax7/
If you are looking for an overview of your supply chain structure in AX7 then you can run the operations infrastructure inquiry. It gives you a way to visualize the companies, sites, warehouse and locations structure below the warehouse. At each level you have some options to view related information. This can be handy to get a quick overview of your setup or help oriented someone new to how the system is setup.
Here is a quick overview.
AX7 Build 7.0.4230.16130
Cheers
Lachlan
Filed under: Supply chain planning
organicax: Creating a category based purchase order in AX7 Blog bot DAX Blogs 0 01.10.2016 04:15
organicax: New released item in AX7 Blog bot DAX Blogs 0 01.10.2016 04:15
organicax: Enabling an employee for MES, Shop Floor in AX7 Blog bot DAX Blogs 0 28.09.2016 22:15
organicax: MES terminal setup in AX7 Blog bot DAX Blogs 0 28.09.2016 22:15
organicax: Sales order processing and inquiry workspace Blog bot DAX Blogs 0 06.04.2016 00:15
Часовой пояс GMT +3, время: 06:55.
