organicax: Lean production flow for simple manufacturing step
Источник: https://organicax.com/2016/09/07/lea...acturing-step/
============== In the setting up lean in AX you will need to create a production flow which defines the activities that you would go through to manufacture a product. You can correlate a activity to a step in a manufacturing route. So it’s a new concept to setup if you are investigating lean in AX. You will need to provide similar details like where does the work get done which is a work center, how long it will take etc. In lean conversion work gets done in a process activity and moving materials in a transfer activity. Because the concepts a little different to a route this is a quick overview to familiarize with the basic setup options and we’ll investigate the parameters in further posts. AX2012 R3 CU11 Cheers Lachlan Filed under: Production control ![]() Источник: https://organicax.com/2016/09/07/lea...acturing-step/
