Axilicious:Dynamics AX7 Add-ins : Deploying separate assemblies
Источник: http://www.ksaelen.be/wordpresses/dy...te-assemblies/
============== A small tip today for those creating add-ins for Dynamics AX7. If you are creating an add-in, the template provides you with a project containing a class for you menu add-in. [Export(typeof(IMainMenu))] public class MainMenuAddIn : MainMenuBase The other thing present in your project is a post-build script that will copy the target assembly to the extension folder of the Dynamics AX 7 Visual Studio extension. By doing so, your add-in will be picked up and loaded by the Dynamics AX 7 extension. While creating some extensions, I often use separate projects that result in class libraries that contain logic. But if you do this, by default, your add-in will throw exceptions that the referenced assembly could not be loaded. This is because your assembly also needs to be in the folder containing the Dynamics AX 7 extension. To solve this, you can change the post-build script to also copy other required assemblies. Look for the line containing: SET InstallingAssembly=%1 And add the following line below. (Note that the sample filter MyProject*.dll needs to be replaced with a filter that matches your assemblies that you want to copy) SET InstallingMyAssembliesFilter=%2MyProject*.dll A bit further, add the following line behind the xcopy line call xcopy /q /y %InstallingMyAssembliesFilter% . That should do it for the script itself. The last thing to do is call it post build. So in the project properties, add the following in the post-build event command line: call "$(ProjectDir)\installtovs.bat" "$(TargetPath)" "$(TargetDir)" Now when you build you solution, you should see the following in your output window: “Copying “C:\Users\Administrator\Documents\Visual Studio 2015\Projects\MySolution1\MyProject1\bin\Debug\MyAddIn.dll” to Dynamics Addins folder C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\Extensions\0ueyjx1c.4xo\AddinExtensions.” 1 File(s) copied 2 File(s) copied ========== Rebuild All: 2 succeeded, 0 failed, 0 skipped ========== Источник: http://www.ksaelen.be/wordpresses/dy...te-assemblies/
