The | (pipe) functionality in Windows PowerShell offers endless opportunities for formatting and manipulating results from one cmdlet to the next.
Coffee Break 4: Piping in Windows PowerShell Each time we run a Windows PowerShell cmdlet, the resulting output is not text but an Object providing structured information of the result. Example: Get-NAVServerInstance will return existing instances of NAVServerInstance Objects: ![]() with the following properties:
Piping example: First import your Dynamics NAV cmdlets (if you are not already in the Microsoft Dynamics NAV Administration Shell, that is): Import-Module 'C:Program FilesMicrosoft Dynamics NAV80ServiceMicrosoft.Dynamics.Nav.Management.dll' This imports the NAV.Management.dll for version 80 (=NAV 2015). Adjust the path to the version you are working with. Get-NAVServerInstance In case Get-NAVServerInstance returns more than one, then let's filter the one(s) that we want by piping the original result through a filter. Or said in other words: We pipe it to the Where-Object cmdlet: #Filter by version Get-NAVServerInstance | where-Object –Property Version -like "8.0*” One can also omit the –Property parameter here, and just run: Get-NAVServerInstance | where-Object Version -like "8.0*” Then we will take the result and pipe that to another cmdlet, let's pipe it to Sync-NAVTenant: Get-NAVServerInstance | where-Object –Property Version -like "8.0*” | Sync-NAVTenant Note also that the syntax of Where-Object cmdlet has changed across Windows PowerShell versions, so for compatibility, and going forward , the following syntax should be used: Get-NAVServerInstance | where-Object {$_.Version -like "8.0*”} | Sync-NAVTenant Where $_ is used to reference the Item returned by the previous pipeline segment (in the above example, it references the instance of NavServerInstance Object returned by Get-NAVServerInstance cmdlet). However running the above will still fail to sync Microsoft Dynamics NAV tenants for instances that are not running (State: stopped). This will not abort the process, but we can also further filter on only those instances that are running: Get-NAVServerInstance | where-Object {$_.Version -like "8.0*”} | where-Object {$_.State –eq 'Running'} | Sync-NAVTenant The two pipline segments filtering the output can of course be combined in one. We join the filtering conditions using –And operator. Note that Logical operators (-And / -Or) are valid only within script blocks. Get-NAVServerInstance | where-Object {$_.Version -like "8.0*” -And $_.State –eq 'Running'} | Sync-NAVTenant See further content about Piping here: https://technet.microsoft.com/en-us/.../dd347655.aspx Jasminka Thunes, Escalation Engineer Dynamics NAV EMEA Lars Lohndorf-Larsen, Escalation Engineer Dynamics NAV EMEA Источник: http://feedproxy.google.com/~r/Micro...ak-piping.aspx
