It has been a while since I last blogged and I am taking the chance now to post on a very delicate argument. The main focus of my dissertation is about performance (Out Of Memory exception, typically) with Microsoft Dynamics NAV 2009 R2, Microsoft Dynamics NAV 2013, and Microsoft Dynamics NAV 2013 R2.
I would encourage you to post your comments and thoughts. Have a good read. Microsoft Dynamics NAV 2009 R2 Considerations (RDLC 2005 - Report Viewer 2008) All the Microsoft Dynamics NAV 2009 stack (RTM, SP1, R2) is built and sealed for the x86 platform. This means that both client (Microsoft.Dynamics.NAV.Client.exe) and server (Microsoft.Dynamics.NAV.Server.exe) are 32bit components of the NAV platform. RDLC Reporting (Enhanced Reporting, in the recent NAV terminology) in Microsoft Dynamics NAV 2009 is made of a Report Viewer .NET Control targeted for WinForm, and Microsoft Dynamics NAV casts this control into a Microsoft Dynamics NAV modal page (that is a WinForm, roughly speaking) within the RTC boundaries. Report Viewer works, in principle, accepting 2 items: - a metadata definition plain XML file (Report.rdlc) that define the structure of the report rendering runtime - a Dataset that is a serialized XML file that contains the data to be rendered in the way defined in the rdlc file definition With Microsoft Dynamics NAV 2009, Report Viewer works client-side to render the report to the user (Preview Layout rendering extension) and therefore it needs to have both RDLC definition and dataset streamed completely from the Server to the Client. This streaming process of Client memory population, since Microsoft Dynamics NAV 2009 SP1, is made with a chunking method that can be resumed in shorts as per below. SQL Server process and generate a complete Result Set. The Result Set is sent to the Microsoft Dynamics NAV Server as normal TCP packets informations and the Microsoft Dynamics NAV Server, meanwhile receiving these packets from SQL Server, is sending this Result Set in chunks to the client, clearing the Microsoft Dynamics NAV Server memory once the packet is received from the client. This has been introduced to avoid memory leak server side that works only as routing point for packets / chunks from SQL Server to the Microsoft Dynamics NAV Windows client. If you open task manager both in the Middle Tier machine and Client machine, meanwhile processing a Heavy report (or whatever report), you might notice that the memory footprint server side is constant and pretty low while the Client one is growing and growing in consumption until it reaches a physical limit. When it reaches its physical limit, you receive the typical error message like the one shown below (explicit Out Of Memory exception) ![]() And, most of the times, report viewer continue clearing the error message and simply display a single blank page (implicit Out Of Memory exception) or several pages with mixed random string value assignments (blurred Out of Memory exception). I do not want to go more deep into the technicalities that lies beneath but you have to consider the following:
Microsoft Dynamics NAV 2013 (RDLC 2008 – Report Viewer 2010) / NAV 2013 R2 (RDLC 2010 – Report Viewer 2012) is another story and challenge type. To resume, the milestone changes between Microsoft Dynamics NAV 2009 and Microsoft Dynamics NAV 2013 (and R2) are the following:
The Microsoft Dynamics NAV Core team is fully aware about these scenarios and working hard on improving the RDLC Report performance and experience in future versions of Microsoft Dynamics NAV NOTE: In this blog post you will find a set of objects (1 Report, 1 Codeunit, 1 Page) to easily simulate an Out Of Memory exception or Save as PDF the report in background. Just import these NAV object set and run Page 50666. You can choose to simulate an Out Of Memory exception by clicking the appropriate Action and then Preview the Report or you can choose to SAVEASPDF the same Report via enabling a Background Session that would do this action Server Side. Be sure to have at least 4 GB of Available Memory Server Side and just wait for the background session to end its activity and stream out the content of the report (this should take close to 5/6 minutes with a standard Cronus database, depending on resources). ![]() These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use. Duilio Tacconi (dtacconi) Microsoft Dynamics Italy Microsoft Customer Service and Support (CSS) EMEA A special thanks to Peter Borring Sørensen & Torben Wind Meyhoff from the Microsoft Dynamics NAV core team. Источник: http://feedproxy.google.com/~r/Micro...amics-nav.aspx
