You probably know that it is possible to import NAV2009+ objects into a NAV 50SP1. At least if your 50SP1 has build 30488 or more recent.
But what you maybe don’t know is that there can be a problem anyway. I had the following error: There are errors in the text conversion (text no. 165-205 does not exist in the .stx file). Internal error: 47-1 AUW! That hurts! The reason is that not all NAV2009-info is deleted in the tables. I exported the fob as text (using NAV2009+) and checked everything. I found these lines: FIELDGROUPS { } Removing these lines and imported it into NAV50SP1 fixed the problem. Not really beautiful as a sulution, but at least it worked. Just hope you don’t need to do it too many times. Читать дальше
