B1.2 Create a report in NAV 2009 using the external assembly
Try to remember once again: The goal is to create a new report using the external assembly.
If you like you can also insert a caption for the report and/or company name and page number etc. At this point we will move into Visual Studio
Now we will setup the external assembly for using in this report.
We will now change the expression of the second textbox calling the assembly For calling the assembly we have to call the Code region – function(variable) name – name of function in the assembly
That’s it. Now it’s time to save, compile and start the report.
Attention: If you have no output or a blank page in your preview, please check if you have a database user in your company because this example is based on database user list…(or use another table ;-) Using External Assemblies in NAV 2009 reporting Part II Using External Assemblies in NAV 2009 reporting Part I Training- NAV 2009 Reporting mit RDLC Advanced Далее
