Старый 28.09.2009, 16:43   #1
When doing a technical upgrade running Microsoft Dynamics NAV CSIDE client on the same machine as your SQL server, please run the CSIDE client with either UAC turned off or with full administrator rights (Run as administrator).
The reason why this is important is because, when connecting locally from a Vista/Windows 2008 server to SQL Server, it will strip down the Windows token from, among other things, honoring builtinAdministrator membership, unless connecting from an elevated command (run as administrator).
This is especially important when doing technical upgrades for NAV 2009 SP1.
This should not be needed if you connect from a remote workstation to SQL server.
These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use.
Читать дальше
Часовой пояс GMT +3, время: 22:07.
