Infolog in batch task history using SysOperation framework
Источник: http://alexvoy.blogspot.com/2016/03/...ory-using.html
============== If you add tasks to a batch job using SysOperation framework, like the following: [...] while (mapIterator.more()) { if (!batchHeader) { batchHeader = this.getCurrentBatchHeader(); } controller = wblDirPartyMergeTaskController::construct(); [...] if (batchHeader) { batchInfo = controller.batchInfo(); batchHeader.addRuntimeTask(controller, this.getCurrentBatchTask().RecId); } else { setPrefix(batchInfoStr); controller.parmExecutionMode(SysOperationExecutionMode::Synchronous); controller.run(); } mapIterator.next(); } if (batchHeader) { batchHeader.save(); } } You need to set Execution mode to Synchronous while initializing your service class controller. // class wblDirPartyMergeTaskController extends SysOperationServiceController public void new() { super(); // default for controllers in these classes is synchronous execution // batch execution will be explicitly specified. The default for // SysOperationServiceController is ReliableAsynchronous execution this.parmExecutionMode(SysOperationExecutionMode::Synchronous); this.parmOther(newValue); } Otherwise you will see nothing in bath tasks history infolog. Источник: http://alexvoy.blogspot.com/2016/03/...ory-using.html
