atinkerersnotebook: The New Dynamics AX Tip #22: Filtering Lists
Источник: http://atinkerersnotebook.com/2016/0...ltering-lists/
============== ![]() The New Dynamics AX is a big change from the previous releases. The majority of the changes are around the new web based user interface, the new way that you navigate around in the application and also new sets of tools that have come along for the ride. For those of you that are familiar with the older user interfaces then you may have to learn a couple of new tricks to get around the system like the pro that you are, and for new users of the New Dynamics AX environments then you will probably want as many tips on all the cool things that you are hidden away within the application so that you can quickly become a power user of the system. I have scoured all of the resources that I have to compile the most useful tips and tricks for the New Dynamics AX and that will be useful to everyone, regardless of if you are a novice to Dynamics AX just trying to get around in the application, or have worked with the previous versions of the system, and are just want to learn the nuances of the new user interface. Filtering lists The list pages are a great way for you to create simple reports directly from the application, but you probably don’t want to see all of the data. We have shown you how you can filter based off the main data, but you can also filter based on any of the fields that are shown on the form. How it works… To filter any of the fields, just click on the Down Arrow icon at the right end of the field heading to pull up the field options. ![]() If you click on the filter criteria you will see that there are a number of different ways that you can filter including contains, begins with, etc. ![]() Then type in the filter that you want to apply to the field. ![]() And then click on the Apply button to apply the filter. ![]() When you return back to the form you will see that the list page has been filtered to just show you the information that matches. ![]() Want more? ![]() Also, if you are looking for more resources on Dynamics AX in general, then make sure you check out the Dynamics AX Companions site at www.dynamicsaxcompanions.com and also the Blind Squirrel Publishing site at www.blindsquirrelpublishing.com for more articles and books. About the Author ![]() Murray is also the curator of the Dynamics AX Companions (www.dynamicsaxcompanions.com) site which he built from the ground up as a resource for all of the Dynamics AX community where you can find walkthroughs and blueprints that he created since first being introduced to the Dynamics AX product. Throughout his 25+ years of experience in the software industry he has worked in many different roles during his career, including as a developer, an implementation consultant, a trainer and a demo guy within the partner channel which gives him a great understanding of the requirements for both customers and partner’s perspective. For more information on Murray, here is his contact information: Email: mcf@blindsquirrelpublishing.com Twitter: @murrayfife Facebook: facebook.com/murraycfife Google: google.com/+murrayfife LinkedIn: linkedin.com/in/murrayfife Blog: atinkerersnotebook.com Docs: docs.com/mufife Amazon: amazon.com/author/murrayfife ![]() Источник: http://atinkerersnotebook.com/2016/0...ltering-lists/
