Старый 03.09.2015, 16:52   #1
syl is offline
syl
Аватар для syl
236 / 21 (1) +++
Несколько источников для QueryBuildDataSource
Доброго времени суток!
Пытаюсь повторить SQL запрос в коде:
PHP код:
SELECT DimensionAttribute.nameDimensionConstraintNodeCriteria.* FROM DimensionConstraintNode
JOIN  DimensionHierarchyLevel ON DimensionConstraintNode
.DimensionHierarchyLevel DimensionHierarchyLevel.RecId
JOIN DimensionConstraintNodeCriteria ON DimensionConstraintNode
.RecId DimensionConstraintNodeCriteria.DimensionConstraintNode
AND((RangeFrom<N'104.211') OR (RangeFrom N'104.211'))
AND ((
RangeTo>N'104.211') OR (RangeTo N'104.211'))
JOIN  DimensionAttribute ON DimensionHierarchyLevel.DIMENSIONATTRIBUTE DimensionAttribute.RecId
order by DimensionConstraintNodeCriteria
.RangeFrom
Query q;
    QueryRun queryRun;
    QueryBuildDataSource qbDCN;
    QueryBuildDataSource qbDHL;
    QueryBuildDataSource qbDCC;
    QueryBuildDataSource qbDA;
    DimensionAttribute da;
    q = new Query();
    qbDCN = q.addDataSource(tablenum(DimensionConstraintNode));
    qbDCN.relations(false);
    qbDHL = qbDCN.addDataSource(tablenum(DimensionHierarchyLevel));
    qbDHL.relations(false);
    qbDHL.addLink(fieldNum(DimensionConstraintNode,DimensionHierarchyLevel),fieldNum(DimensionHierarchyLevel,RecId));
    qbDHL.joinMode(JoinMode::InnerJoin);
    qbDCC = qbDCN.addDataSource(tablenum(DimensionConstraintNodeCriteria));
    qbDCC.relations(false);
    qbDCC.addLink(fieldNum(DimensionConstraintNode,RecId),fieldNum(DimensionConstraintNodeCriteria,DimensionConstraintNode));
    qbDCC.joinMode(JoinMode::InnerJoin);
    qbDA = qbDHL.addDataSource(tablenum(DimensionAttribute));
    qbDA.relations(false);
    qbDA.addLink(fieldNum(DimensionHierarchyLevel,DimensionAttribute),fieldnum(DimensionAttribute,RecId));
    qbDA.joinMode(JoinMode::InnerJoin);
Поскольку строка qbDHL = qbDCN встречается несколько раз, запрос карежится. Подскажите как добавлять несколько источников к одному QueryBuildDataSource
Старый 03.09.2015, 17:17   #2
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
А так?
qbDHL.fetchMode(QueryFetchMode::One2One); // <--
Старый 03.09.2015, 17:24   #3
syl is offline
syl
Аватар для syl
236 / 21 (1) +++
По дебаггеру после выполнения данного кода:
в переменную q пишется запрос, затем после добавления этого кода:
переменная очищается и запрос тупо не генерируется.
Ничего не меняет
Старый 03.09.2015, 17:30   #4
Товарищ ♂uatr is offline
Товарищ ♂uatr
Аватар для Товарищ ♂uatr
332 / 913 (31) +++++++
Попробуйте джоинить не в параллель, а каскадом.
qbDCC = qbDHL.addDataSource(tablenum(DimensionConstraintNodeCriteria));
Старый 03.09.2015, 17:34   #5
syl is offline
syl
Аватар для syl
236 / 21 (1) +++
Пробовал. Тогда :
В запросе выглядит как
DimensionHierarchyLevel.RecId = DimensionConstraintNodeCriteria.DimensionConstraintNode
а должно быть
DimensionConstraintNode.RecId = DimensionConstraintNodeCriteria.DimensionConstraintNode
Старый 03.09.2015, 17:58   #6
Товарищ ♂uatr
qbDCC.addLink(fieldNum(DimensionConstraintNode,RecId),fieldNum(DimensionConstraintNodeCriteria,DimensionConstraintNode), qbDCN.name());
Остальные по аналогии, если эта же проблема повторится.
Старый 03.09.2015, 17:56   #7
syl is offline
syl
Аватар для syl
236 / 21 (1) +++
Я и не меняю. Оно по умолчанию хватает как родителя последнего добавленного. И в итоге портит условие соединения в запросе
Старый 03.09.2015, 17:59   #8
syl is offline
syl
Аватар для syl
236 / 21 (1) +++
Странно, но заработало так как вы говорили:
    qbDCC.fetchMode(QueryFetchMode::One2One);
В SQL Server запрос возвращает 3 строки, а тут только одну. Как исправить?
Последний раз редактировалось syl; 03.09.2015 в 18:17.
SQL в QueryBuildDataSource syl DAX: Программирование 6 02.09.2015 15:58
QueryBuildDataSource Emka DAX: Программирование 3 06.05.2015 11:51
Несколько отчетов в одном вьювере IKA DAX: Программирование 3 20.08.2013 16:17
QueryBuildDataSource - динамически if_maks DAX: Программирование 6 07.04.2006 13:39
Вопрос по QueryBuildDataSource, QueryBuildRange и QueryRun Paul_ST DAX: Программирование 9 11.02.2004 17:13
Часовой пояс GMT +3, время: 06:53.
